My 997 s '05 with 15K mileage developed a strange 'play' on the brake pedal. If I use the brake and keep the pressure on and then start moving the pedal vertically for 0.2 inch (up and down several times) there is some play on it. The feel can be compared with a normal house door handle where the handle has some play on it before the mechanism start to give counterpressure. I know that it is a bad description of the problem, but i don't know how I could describe it much better.
If this rings a bell, please post your thoughts.
Thanks, frank
