Looking to retrofit Navigation into my 06 Carrera S with PCM/Telephone module. What parts are needed, I've come up with the following:
Navigation DVD player (possible part number 997.642.137.02)
Optical cable (possible part number of 997.622.713.00)
Antenna GPS (997.642.105.00?)
DVD maps and updates
anything else? Will I need to upgrade the PCM with part number 997.044.901.34, seems like the PCM is the largest cost in this part number, will the original work?
thank you in advance
There is a TSB for this complete install.
Actually there are two TSBs depending on the build date of your car.
Be careful - 997.044.901.34 is only for MY07 cars built after week 22 of 2006.
You will also need the correct fiber optic cable kit fot the options that are currently in your car.
Car was built November 2005, so I guess they looked up the wrong number. Do I have to replace the existing PCM in the car? How do I get copies of the two TSBs? thanks
How to become a Contributing Member
Fitting the navigation drive and GPS antennae is relatively straight forward. You will probably also need the navigation drive bracket for the front trunk , as well as the optical MOST cable that links the PCM with the navigation drive and a power cable lead for the navigation drive. There is also a cable to link the GPS puk with the navigation drive. Your PCM may well be old software ie version 1 or 2 , this will need updating to version 3 to allow the new maps and navigation to work correctly. This software is usually bundled with the MAP DVD from the dealer.
When purchasing the fibre optic cable, it is wise to buy the one for Bose (if you have) and cd changer. I've had this retrofit done (I bought the parts) and that was the reccomendation of the Porsche dealer parts man. I was well pleased with that suggestion as I later added the changer. I paid just under $2000 for all the parts for my '06 997.
donlycan
Are the locations for the junctions of the Optical cable, etc obvious or are they hidden? Also, is a PCM update required, that is, is there a navigation PCM and non-navigation PCM? Do you have to do anything inside the console as far as cable connections? How did you acquire the correct part numbers and if you get parts that were manufactured after the purchase date of the car, will that require additional work?
What about the horizontal vs. vertical DVD Drives; I understand if you use a horizontal drive in a vertical position, it causes some GPS issues, but what about a vertical drive for the horizontal position assuming that I can't acquire a horizontal drive for a good price?
I just went through my install and you need make sure you get the right parts!
do you have a C4 or C2? C4 takes vertical mounts and the C2 takes horizontal mounts. also, with or without bose? with or without CD changer
I believe the PCM is all the same and works with the Navi, no need to update, but this i'm not sure.
hope this helps!
C2 without BOSE
997.622.707.00 Optical waveguide, without CD changer
997.622.715.00 Optical waveguide, with CD changer
C2 with BOSE
997.622.710.00 Optical waveguide, without CD changer
997.622.713.00 Optical waveguide, with CD changer
C4 without BOSE
997.622.722.00 Optical waveguide, without CD changer
997.622.725.00 Optical waveguide, with CD changer
C4 (997) with BOSE
997.622.717.00 Optical waveguide, without CD changer
997.622.720.00 Optical waveguide, with CD changer
Where do I find the TSB for the navigation system? I have been looking at the documents menu but I cannot find.
Go here
Type PCM in the Search box at the lower right - you will get 16 TSB results.
Hi all,
I gathered all the different pieces to add the Navigation to my PCM 2.1 on a 997-1 C4S but I still have on missing, the holding bracket for the dvd drive.
My dealer tells me he need the correct part # to order it.
So far I have :
Dvd drive: 997 642 157 01
Cables : 997.622.720.00 (Optical waveguide, with CD changer and BOSE)
The antenna
DVD updates for my PCM and the NAV
So i guess i'm missing the bracket to install on top of my bose amplifier in the trunk.
Anyone knows the part # ?
Think i'm missing anything ?
Many thanks
Hi all,
So far I have :
The antenna
Many thanks
:welcome:
There is an installation TSB (available here to our Contributing Members) that lists all the parts.
Plus the fiber optic cables required for your car will vary based on what options you already have.
I suggest becoming a Contributing Member and downloading the 14 page TSB.
How difficult it is to run the fibre optic from the trunk to the PCM? Is the back of the PCM easily accecable?
All the questions are answered in the TSB.
