Alarm codes
I got a CEL and was getting the fault codes with my Durametric. As it has been a long time since I did any code reading I checked all the fault codes and besides the P1126 for the CEL I got 3 Alarm codes whose meaning I can't seem to find. If anyone can help me it would be greatly appreciated.
49 KLEAD ?
33 Interior Sensor Faulty
21 w lead DME Immobilizer
Thanks in advance for your consideration. Ed
Edited by Loren
Moved to Boxster forum
Settle down folks...
Fault code 21 - W lead (DME - immobiliser), open circuit
Possible cause of fault
- Short circuit to ground/open circuit in the communication lead between the alarm system control module and the DME control module
Fault code 33 - Passenger compartment: monitoring sensor faulty
- Passenger compartment monitoring faulty
Fault code 49 - Klead
- K lead connected to ground for at least 2 seconds after ignition is switched on
Have you checked to see if the alarm control box (under the left front seat) got wet?
So I neglected to add Boxster to the 1998 part, and you neglected to be human. I guess we are now even
I am sorry, I suppose you have difficulty with reading (this response delivered from a computer)...so what's up with the personal attack?
lighten up and please respect the posted guidelines....for your assistance:
It is really helpful if you list:
· Model year
· Model/Engine (i.e. Boxster 2.5, Boxster 2.7, Boxster S, Boxster S Special Edition, etc.)
· Transmission type (i.e. 5 speed, 6 speed or Tiptronic)
· Interior color (when relevant)
· Country specific information (LHD, RHD, RoW, US, Canada)
That was the first thing that I checked and the rug didn't seem wet, nor was there any signs of corrosion inside the box. I don't seem to be having any troubles. Is there something that I should do or just clear the codes and see if they return. Thanks for the information. Ed
