When I am crawling (when there is little road noise) I can hear "creaking" sound from the front end. Is this something I should worry about?
Most likely a loose sway bar or shock mount. There was a TSB for earlier cars about bad strut mount bearings but, I have see this on a couple of newer cars too.
  • 3 months later...
rl_diamond:
I have a (new) 2000 996 C4. Within 2 weeks it was exhibiting the creaking noise you describe from the front end. The dealer fixed it under my extended warranty. They replaced the right front lower control arm - creak gone. My dealer is suggesting this is becoming a common problem, they have seen 4 other cars with this problem recently, all C4s.
Edited by PeterC4
