I just left the dealer and they were unsuccessful at programming this feature. I wanted the the doors to lock at drive-off, is this not an option on the 6GT3?
Thank you.
Hi Loren,
I'm in Los Angeles and the dealer was L.A. Auto Gallery in Woodland Hills. I saw them hook-up the PST, but I think that they were programming the other auto lock function (when the key is removed from the ignition and the doors are closed)?
On a PST2 or PIWIS four versions can be selected under the 'Version coding' menu item.
Version 1
The doors are automatically locked as soon as the ignition is switched on.
Version 2
The doors are automatically locked if the vehicle exceeds a limit speed of 5 km/h.
Version 3
The doors are automatically locked as soon as the ignition is switched on. If the doors are opened while the engine is running, automatic re-locking takes place if the vehicle exceeds a limit speed of 5 km/h.
Version 4
The doors are not locked automatically.
I have never seen a car that the correct programming did not work.
  • 2 months later...
I finally got the car back to the dealer (this time I took it to Rusnak/Westlake) to have the updated RMS installed and while I was there, they programmed version 2!
Thank you Loren.
