Title says it all -
Purchased a hard top for our Boxster and need to paint to match. Can see how to take off the side weather stripping easily enough but looking to see if any one has taken it to the shell for paint?
Hi, I just dropped my top off this morning to a local body shop for repainting to match my car. I stopped by on the way home from work and it was all disassembled. They carefully pried the two metal strips off of the top from around the gaskets. Basically there are 4 plastic clips that hold them on. The rest was pretty simple they said, they did leave the glass in however. They had stripped the inside lineing out as well. If you like I could get some specifics but the way they spoke it was pretty straight forward. you could check out https://dcauto.gotdns.com no www in there.... i found some good exploded view drawings. I have never bought anything from them so i couldn't tell you about their customer serivce etc. Hope that helps
