my engine check lights since yesterday. My speed idle is not working when i am driving, and the digital speedometer too (shows 0 km). I have checked the fault code with my engine Scan tool, and i recieved following informations:
P 0501
Vehicle Speed Sensor A Range / Performance
My questions:
-On which wheel is the Speed A sensor located?
-How can i fix the problem? Cleaning the speed sensor will help? Or should i replace it?
Thanks for your help.
Lenny
it is the rear-left wheel speed sensor output of the ABS.
VSS generates a pulsing voltage every time the vehicle speed is beyond 3 mph,
supplies vehicle speed information to the ECU,
ECU supplies the requisite signal to the cluster,,,,might want to reset the DME.
Have you touched the stereo wiring rescently? I've seen VSS/GAL signal shorting out too
Edited by juniinc
So, is it enough to clean the sensor? Or should i replace it?
