You will need to know the offset and width of these wheels. If they are off a TT (widebody), They will not fit a 996 C2 coupe
Front;
Offset: 50mm
Backspacing: 6.46" Bolt Pattern: 5-130
Rec. Tire Size: 225/40-18
rear;
Offset: 65mm
Backspacing: 8.10" Bolt Pattern: 5-130
Rec. Tire Size: 265/35-18
This is what is on my car.
J. Greer
Yes, I believe they are for the TT (wide body). I'll find out what's the off set of the those wheels.
Cheers
