I recently replaced all the rotors and pads (Pagid) on my '99 Boxster. The front pads were worn into the brake wear sensors so I replaced the sensors. The rear pads were not badly worn but I replaced them anyway.
I "bedded" the pads as per the Pagid instructions.
Now I have a horrible brake SQUEAL at very low pedal pressure. Also the brake wear light will not go out??
I spoke with a tech person and he said to grind down the trailing edge of the pads and that would eliminate the squeal, it did not!!
Can anyone give me some ideas to correct these issues?!
