How do I change my 2006 Boxster tail light?
Also how do I get to my Bose subwoofer to push in a loose cable? Thanks
The taillight is easy
1) Open the trunk
2) behind the taillight in the trunk you will find 2 plastic wheels that hold on the carpet trim piece. Remove them by unscrewing by hand
3) Fold the now free carpet trim piece back, inwards toward the center of the trunk.
4) You will now find 3 long bolts that each has a flange nut on it. Remove the flange nuts with a small ratchet and socket (3/8 I think)
5) near the center top is a multiplug. Squeeze two tabs on it toward the center and pull toward the front of the car
6) slide the light unit out as a piece from the outside of the car towards the rear.
Note that if you only need to change bulbs you can do that with the light unit in the car. Just follow the instruction in the owners manual. It starts by doing steps 1-3 above.
Edited by renzop
