The top is stuck half way up ...brake light on battery ok. Any ideas?
First check fuse. 30 amp i think #13. If thats ok, On soft top header insert straight screw driver into access holes and tighten both sides. You may remove panel( 2 screws and clips) for easier access. Tighten till gears move. Then try switch again. Make sure Ebrake is on
