I have a 02 Carrera (6-speed) coupe and I would like to retrofit the 996 GT3 adjustable sway bars. Does anyone have the part numbers for the bars (including the part numbers for bushings, etc.). Thank you!
  • 3 months later...
I ran across this number 996.343.701.90 for the front and 996.343.792.16 for the front bushings. I am trying to find out the specs for this bar (i.e. outer/inner diameters and possibly length between the bar ends. I could come up with a reasonable estimate if someone could measure the bar diameter (with paint) and the crimped end. I have seen this bar spec'ed at 26.8mm, but I had someone tell me that this is wrong (a Porsche dealer).
