Hello Everyone;
I am new to the Forum and i have just purchased my first Boxter. 2001 Base.
I would like to change the pads and rotors the car only has 36000 kilometers, but hte brakes need changing and are all stock. I would like to install cross drilled rotors and new pads.
1) Do i have to change the calipers from the stock setup to use cross drilled rotors?
2) any suggestions as to which parts to use? ( brand name)?
Brett
Hello Everyone;
Brett
check out the link below
http://mike.focke.googlepages.com/mikespor...boxsterwebpages
good luck
Edited by eddison
are you sure that the brakes need changing, or is it just that you want to? ;)
36000km = ~22K miles. my original pads and rotors went almost 80K miles before needing replacement - and even then i could have stretched it another 3K miles. it doesn't seem likely that your car *needs* a brake job unless it has been tracked/raced/etc.
now, if you *want* to change brakes for a better look, there's nothing wrong with that if you have the money.
http://www.designrt.net sells Zimmerman rotors (OEM) that are cross-drilled and/or slotted for use on non-S cars. cost is approximately $350. FREE shipping, too! it doesn't look like they have the Boxster rotors listed on the website, but give them a call, they do sell them. you'll want to get the rotors with the painted rotor 'hats' so they don't rust. you can choose the color.
as for pads, i use Mintex Red Box pads and you can find them on eBay for ~$50 per axle. they work great and don't dust too much.
here's the link for the brake DIY: http://www.bombaydigital.com/boxster/projects/brakes/
the site above that 'eddison' pointed you to (Mike Focke's Boxster Pages) is invaluable to any and all Boxster owners - BOOKMARK IT!
and the most important thing, 'Boxster' has an 'S' in it!! :D
good luck!
good luck!
:unsure:
Thanks for all the input. Boxster does have an S. oops! How can you tell i am a newbie!!! LOL.
I will check out the sites.
Brett
