Hi I have just bought a CD changer and bracket for a cayenne. Just a few things though, where does the CD changer go and is the car pre-wired?- How do I check? Also if the car isnt pre wired is it easy enough to add? :help:
Any help would be much appriciated. :notworthy:
Thanks :) :) :thankyou:
I believe it should be pre-wired for the rear CD changer on the 2006 Porsche Cayenne Turbo S. Mine was ('04 S), it's just a pain to get at the left side bolts when attaching the changer to the bracket (bracket was already there too). Make sure the fibre plugs are correct and the install should be plug-n-play.
Good luck!
