Working on a 2.5 98 boxster and having a few issues!
Car came in with exhaust blow and CEL on, fault was cleared and pre-cat lambda on 4-6 replaced, car also had a full service at the same time.
Now the cars totally lacking power like the MAF's shot but even unplugging the MAFs given no noticable increase in power, can't see any obvious air leaks so not sure whats at fault. PST2 shows no fault codes anywhere.
Only think i can think of is a dodgy plug gap or two somewhere but as new plugs were used theoretically they should be fine (assuming some parts monkey hasbn't dropped them!)
Any other suggestions?
A quick answer would be to check the TB for grunge buildup and use techron injector cleaner. (that's the simple quick answers) A really filthy air filter comes to mind as well.
Some things to consider at anyrate.
Is the clutch slipping? ( the motor revs going up but speed isn't).
Are you sure about the cat's, they can particularly block the exhaust if the ceramic element is broken.
