Hi guys,
Just wondering if any alignment tool has been released for the B&M SSK. I have followed the topics and the last I have seen there were a multiplicity of tool colors, but none fitting the B&M...
Is anything available as of yet?
All the best,
Gus
I was going to have someone I know try to make one. I showed him the standard and B&M shift, and the 2 versions of the factory tools. What I need is to borrow a B&M already installed in the black plastic housing, so I can give it to him. Any local owners with an installed B&M but not in the car?
I was going to have someone I know try to make one... What I need is to borrow a B&M already installed in the black plastic housing, so I can give it to him...
That is great news,
I am in NJ, otherwise I would most certainly lend my installed B&M
Keep us posted
Best,
Gus
A few years ago, vfxbox borrowed my shifter adjustment tool and started to make one for the B&M shifter - see http://www.renntech.org/forums/index.php?s...amp;#entry46389 You might want to see if you can contact him and find out whether he ever got it working
I think you can get everything aligned with the stock shifter, in terms of cables, etc., then swap in the B&M without messing with the cables and everything should work OK
Unfortunately the vfxbox plan went nowhere.
This is what I need. A B&M installed in the housing. From a local owner who does not need it for a few weeks.
