I have a MY99 996 C2 and would like to add some extra power.
Can you that have experience please comment of results and equipment you use.
Like ECU, Exhausts, Airfilters etc..
It would be nice to get some feedback before you spend a fortune on something that is total waste of money..
So, the best way to get good power without having to sell all you own :rolleyes:
A note on tuning your engine. Regardless of what you do, whether it is software or exhaust, etc, make sure you verify what the engine parameters are after the mods. Particularly timing and A/F ratio. This can be accomplished by using a scanner and taking a reading of the sensors at various engine loads and speeds. You should also record your warm engine vacuum reading at idle with A/C off.
Unfortunately, many backyard tuners as well as professional tuners, make changes and later find out that their mods make the engine run outside safe parameters. It is always good practice to log the readings of all sensors prior to making any changes at various engine loads and speeds.
Regarding the specific mods mentioned; a more free flowing exhaust will cost you lowend power but may free up engine breathing at or near redline. A freer flowing air filter, assuming it draws air from outside the car, will give you some improvement in throttle response and some more power, but nowhere near the additional power many companies claim. Biggest benefit of an open filter (cone), is the change in engine sound.
As for tuners, this will get you the most power improvement but at a substantial cost. Tuning of an NA engine simply involves timing changes as well as may include modifications to the fuel maps. Bottom line is that most of them result in only moderate increases in power and some obtain the added power from leaning out the engine, which, in most cases is safe for the 996 since the factory program is set to run slightly rich.
Like I said, log the readings of all sensors on your engine BEFORE making any mods.
To make significantly more power, you would need to go with forced induction or chemicals to increase oxygen levels in the cylinders.
Add a good $100 oil air filter. Wash it and oil it
every 10,000 miles. Wrap it in newspapers after you
oil it and wait a few days.
There are some positive stories on this site about
this simple add.
Paul
Dont waste your time and money. The performance increase will be 'slight'. Save your money and get a 996 Turbo. Then if that isnt enough, get an ECU remap and that will give you another 60-80bhp alone.......... That would be my advise.
So i can see that tempering with mapping is to risky and to much work..
Is there a risk with just changing the exhaust and mayby the filter??
Thanx everybody for responding..
And yes, i guess that the next one will be the Turbo car, but i just bought this so i think it will be good for a couple of years..
Jan
here:
http://www.renntech.org/forums/index.php?showtopic=21788
bottomline - if you want a stock 996 keep it stock. It is not bad...but to me it was kind of boring after the initial thrill of owning a 996 wore off....
if you want a 996 that sounds better and has some more power - then by all means add coldair kits, plenums and exhaust
do you want to tune the motor for all of it - add a ECU flash to optimize the mapping/timing -
total cost should net exceed - 3000.00. And if you are a smart buyer you can get it all for less.
then do you want your 996 to handle stock or better? then you are faced with other options - coilovers and swaybars...to me this was a better 1st investment to adding power. Power makes a stock 996 handle even worse IMHO because now you push the car to higher limits and the stock suspension just is not good enough, unless you desire higher amts of body roll. total cost 1900 - 2400.00
then do you like sloppy shifting? Then keep your stock shifter.....otherwise a B&M SSK (short shift kit) or for you Porsche fanatics (the Porsche SSK) will
enhance the driving experience...total cost 199.00 for a B&M
anything over these mods....I do not see the point. Just buy a TT
