O3 996tt- dash and center console has some nicks from rubbing key's and other assorted things. I am wondering if there is a touch up kit that exists for this type of thing?
Edited by Junior1
O3 996tt- dash and center counsil has some nicks from rubbing key's and other assorted things. I am wondering if there is a touch up kit that exists for this type of thing?
Good luck, I searched high and low and could not find a match (graphite grey), wound up buying a new center console, which really was not that much of a wallet hit.
Ok, thanks. I have searched as well and could not locate anything, my center console is Graphite grey as well. Where did you get the replacment and how much? Any challenge putting it in?
It cost me about $120 before shipping. Use the collision catalog search boxes. Bought it here: http://www.trademotion.com/partlocator/ind...CFReQGgodj2UgCA
It's not a tuff thing to do, everything snaps off just becareful when removing the storage box switch and wire. If the current storage box has the old hinge set, you will also have to buy the hinge kit, not expensive.
Use the instuctions to change the shifter out to a short shift kit. It has all you need to remove the console. My only suggestion is when you remove the side cover that encloses the handbrake lever. Wrap the lower section with tape. This will keep it from getting scratched when removing and replacing the console.
Edited by KevinMac
