After 1-2 laps of a 4 mile circuit the brakes start to judder and the whole car vibrates when the brake pedal is pressed. They are still effective but got me thinking something's not right!
Did a few laps with cooling down rests in between and there was no deterioration in the braking performance - but the vibration was like going over a cobbled street at 70mph!
After coming off the track drove home 50 miles - no problems at all.
The pads and discs look fine from what is visible without taking the wheels off
It simply doesn't happen when the brakes aren't hot
The only thing done recently (since the last track day) was a brake fluid change by an OPC. DOT 4 to DOT 4.
ABS still functional
I understand it's a good idea to upgrade pads, discs and fluid but I don't feel this is the source of this problem, as I would do 5-6 laps without any problems previously.
Thanks in advance for any advice.
