I recently acquired a 2006 C4S and wanted to update the PCM and Nav to the latest software and nav maps, so I got the update from Suncoast and followed the TSB and it worked fine. Since it was an '06, it already had the 05025xxx Model Level B software (version 3.2), so I only need to update the Nav firmware and put in the new DVD map disk.
I had read that version 3.3 improves the telephone quality and MP3 playback which I'm most interested in getting, but the Suncoast update package does not include the Model Level C update to 3.3. I believe someone referred to it as 000 043 205 46 007. Is that correct and any idea how I can obtain this update without a visit to the dealer?
Any guidance from the experts here would be much appreciated.
You can get the discs, which include the firmware updates and an updated map from the dealer, although the TSB 32/07 states that the firmware should only be done by the dealer it is quite straight forward.
The correct part number is 997.044.901.51
Edited by Nick_USA
See Navigation system update several Posts below!
