I'm a first time poster. About a month and a half ago I bought a 2003 Boxster with Tiptronic and 28,000 miles and I absolutely love it. Once a week I have a 45 mile commute between Roanoke and Blacksburg, VA. Along the way is a good size mountain range that I cross on Interstate 81. In my old Saab 900 Turbo with a manual transmission I used to enjoy coasting for two full miles coming out of the mountains on my way home. I would even do this when driving my wife's Volvo S70 with its automatic transmission. For some reason I enjoy the soap box derby effect of covering long distances without assistance from the idling engine.
Is it a bad idea to do this with a Triptronic? I've done it a couple times with seemingly no ill effects but it is a little more unnerving to do so with the extra button push required to pull the transmission back into drive from neutral.
What do you think? Is this harmless or a bad idea?
Trevor
P.S. The owners manual has a sentence that suggests neutral should only be used in limited situations where slipping is occurring.
Trevor
Putting ANY modern automatic car in N while at high speeds is usually a no-no and good rule of them to NOT do. I've owned several makes models with different trans manufactures but I know for a fact ZF and Asian both do not recommend on some models. I cannot image the Tip would like it either but I do not know for sure on your make/model.
If you do a search on a recent (painfully) long email on the discussion of idle for engine braking and gas consumption you an draw you own conclusions based on theories that have such a minor saving in your pocket book it's not worth considering.
He said nothing about high speed driving. If the car is
idling at 40 MPH my opion is it will not make any difference.
It probably saves gas also. I would enjoy your car
and drive it like you want.
Paul
Paul
I think we can assume that that coasting a mile or two down a mountain pass is going to cause speeds in excess of 15mph. With modern transmissions the issue is not with "coasting" in N at a higher speed it is the required shift in and out of N at higher speeds that some cars don't like.
and drive it like you want. :D
Paul
I wouldn't do it with any automatic tranny, let alone a Tiptronic. :o
