what is the best coilover for 996 c2? i'm thinking about getting coilover and sway bars. i did some research and found out kw, h&r and radersedge makes good coilovers. i don't mind the stiff set up for street.
thx
chris
Bilstein makes the pss9 that has adjustable shocks. It can be adjusted soft enough for the street and set firmer for the track. Use that or the H&R, I would not trust anyother brand because thoes two makes parts for the manufacture. H&R makes sway bars that are reasonable in cost. The GT3 bars are good, but cost twicw as much. M030 bars are good, but might be soft if you're gonna track it.
i have looked and decieded to go with pss9 and TRG sway bars. cost on TRG sway bars are little high but it comes with drop links and it's complete kit. anyway, i'm looking for good price on pss9. where would you guys buy it from?
