1999 C4 Cab The rubber seal along the leading edge of the cab top does not draw tight above the passenger window. The issue is above the middle of the three plastic pieces above the window. There is an elastic strap below the top which apparently is meant to direct the fold as the roof lowers--this strap seems to pull the leading rubber edge bead out of the track slightly. Any suggestions?
