Hi All
I have a creaking and clunking when I move forward or reverse . It sounds like it is just under the arm rest in the gearbox engine area. It happened a few months ago and then dissapeared, at that time I thought it was the handbreak (It thought the cable was sticking)as it did not happen if it was not used. Now it is back ant every time I take off in forward or reverse.
I did have the car up on four jackstands to replase my clutch slave cylinder and I used the engine jacking point it started the noise when I finished the work .
Could this be an engine mount(how do i inspect the engine mount and how do i identify a failed one)
Any greasing points on the 996 that need grease?
Any suggestions to the problem noise and apossible solution
Christopher
MY99 manual C2 cab 59K
