I would think the manufacturer of the camshaft could best answer that question. Have you contacted them? Sorry I can't answer your question.
I have no knowledge of these particular camshafts, but I have found that you get much better performance gains if you make sure the camshaft is matched to the heads and intake. Replacing just one of these things in a stock set up usually doesn't land you too much, but if you can find the right set up to work together, it can be amazing.
thanks you guys
