OK, heres a little poll:
If you're a tip owner, tell us:
1) How many miles your car has on it
2) Any tip problems
3) Your tip maintenance history
I'm trying to correlate tip maintenance with tip failures.
Thanks guys (and gals)!
1) 44,000 km
2) sometimes for no apparent reason, a tip emergency light comes on and goes off again in a few secs. cars drives like nothing happened.
3) new owner, plan to change atf, all of it, and check electrical stuff/wiring
51k
changed fluid and filter at 43k because of age of car
no problems as of yet
2005 997C2S tip TPC supercharged
25k miles 2nd owner no tip problems
no maintenance done yet
I have a 2006 997S.
It has 52,000 miles.
No problems at all. It still shifts like new.
I had the fluids changed at 49,000 miles. It took the
factory mechanics twice as long to do it. They have to run
the car and change gears before they top it off.
Paul
  • 6 months later...
MY03 Boxster
purchased with 54K miles sept 2007
1. 73k plus
2.
a) at 64k = bad leak due to front pump bushing seizure on T/C hub (replaced front pump and
remanfactured T/C)
B) at 73k = leak not as bad as (a) still working on the problem. most likely replace or remanfacture
T/C and replace Seal.
3. unkown before 54K (1st owner)
One suggestion: I would also ask about driving/shifting habits, how often use M vs D mode?
my driving habits . 99% M mode
2) Any tip problems
My old 99 was
26k
zero problems
zero maintenance
and
My current 01S as
55k
zero problems
zero maintenance
I drive in A 95% of the time, seldom am I demanding even when in M mode and then only when warm.
2002 boxster base 2.7
68K miles
Zero problems
All regularly schedule maintenance as per the owner’s manual
95% driven in auto mode
  • 4 months later...
