Hi guys, my window makes a squeeking sound.
could it be that door panel is too tight, I recently had it removed for speakers upgrade,
but that was 2 weeks ago, and the noise started yesterday.
Mine was squeaking and when it rolled down the outside weatherstrip would stick and fold into the window. I haven't had time to tear the door apart, so I finally ended up rolling the window down and spraying some dry lube inside the weather stripping. It stopped by squeaking and binding, but for two days the window was a mess as I didn't want to clean it off until I was sure everything was good and lubed.
  • 4 years later...
Mine is doing the same thing. Binding and making an awful sound. I'm wondering if adjusting the inboard/outboard adjustments at the bottom of the door will help alleviate some of the pressure between the glass and the outer weatherstrip? Anyone have any ideas?
clean and wax the window, then spray/wipe/apply some rubber lube to the seal. a little bit goes a long way.
