Hello all-
My 99 C2 has had the check engine light on for a while so I took it to a local dealer and had them read the diag codes and give me likely reasons for them. To save a bit I plan on doing whatever parts of the repair I can myself (starting with replacing the MAF sensor).
Without the Porsche computer will I be able to "reset" the code to see if the problem is solved? I may not be using the right terminology.
Thanks in advance!
-Tom
