Searched and found nothing. How do I remove/replace the tiny bulb in the door pull that lights up the igniton when lights are on?
Hmm.. I thought that was an LED - and should last almost forever.
I guess there could be a wiring problem in the door panel.
It is item 12 in the diagram.
Found the problem. Broken resistor(?) at the light. The 7-8" harness has 2 LEDs (ignition & handle) that are on the same circuit. Soldered in a new resistor and will install ASAP. Hope it works.
