Hey everyone, newbie here!
I got a 97 boxster that was in a wreck. I cant get the key out? Also, I keep reading that the keys are programed, but mine doesnt have enough room in the plastic peice to hold a battery? I only have one key also. I tried searching the word "key" but nothing come up.
thanks in advance!
thanks in advance!
i would agree with Richard on the ignition unit. check position of key if its off then definitely the ignition switch. tip of removing the key, sometimes if u keep on turning it back and forth it will bring it back to position and u will be able to remove it. it worked for me. good luck
Anyone know what model audi uses the same switch? My local parts dealer cant find it using th epart number(no big shocker there) but if I can give them the exact model/year they may be able to find it
thanks!
