need full instuction on how to flush the radiator.
car has 80000km now.
thanks
You mean something like this.... Note I didn't notice mention of specific year and model ( V6, V8, Turbo, Turbo S....)
( however the diagrams, charts, and drawings do not translate properly to this format. If you want full info contact me about workshop manuals)
19 01 29 Cooling system cleaned (after oil/coolant mixing) - as of MY 2003
- Cleaning the cooling system
Tools
Designation Type Number Explanation
filling device special tool 9696
top of page
ATTENTION
Danger of poisoning!
Coolant additives and cleaning liquids are toxic.
→ Swallowing coolant additives and cleaning liquids must be urgently avoided.
→ Do not consume any food or drink while working (danger of accidental mixing).
→ If swallowed, observe the warning information on the containers and contact a doctor. If necessary, show the doctor the warning information on the packaging.
DANGER
The vehicle fans can continue running or start up automatically.
Injuries which can lead to the loss of body parts.
→ The power supply to the fans must be disconnected before starting work on the radiator, radiator fans, or the belt drive. → Disconnect fuse carrier [9PAAE1 9PAAE7 9PAAF1]→ Disconnect fuse carrier [9PAAD1 9PAAD7 9PAAJ1] or battery → Work instructions after disconnecting the battery
ATTENTION
Risk of damaging the cooling system!
→ Do not relieve the system pressure of the cooling system and then run the engine.
→ Relieving the system pressure and subsequently starting the engine can cause severe damage to components in the cooling system. If the cooling system must be opened when it is hot, allow the cooling system to cool down before starting the engine again.
Note
The coolant filled in at the factory is intended to suffice for the entire service life. As long as the coolant is not contaminated by foreign bodies or other fluids it need not be changed.
Different coolant additives must not be mixed and doing so may damage the cooling system. Only use original Porsche coolant additives.
The coolant must be set to antifreeze protection of -37 °C. This corresponds to a mixing ratio of 50 : 50 (coolant additive : water). This mixing ratio provides optimum corrosion and antifreeze protection.
Coolant additives, coolants and cleaning agents must be disposed of according to the respective, applicable national laws.
Seals in the cooling system must be replaced by new ones following disassembly.
Draining cooling system 1. Drain cooling system. → 193817 Draining and filling coolant (includes bleeding)
Note
The cleaning work steps must be repeated until no more oil rises to the surface in the coolant reservoir.
The radiator cleaning agent mixture must be approx. 23 litres in the filling canister of the filling device filling device 9696.
The cleaning agent is mixed with water at a ratio of 50:50 (Frostox R Spezial).
2. Fill the cooling circuit with the cleaning agent mixture. To do this, proceed with the cooling system analogously to filling the coolant. → 193817 Draining and filling in coolant (includes bleeding) - chapter on "Filling in"
3. Start the vehicle.
4. After the vehicle has been bled and the coolant temperature is > 80 °C, let the stationary vehicle run at medium engine speed for at least 15 minutes.
5. Switch off engine.
Coolant reservoir ATTENTION
Danger of scalding with hot coolant!
→ Never open the cooling system when it is hot. Emerging coolant may be very hot and can cause scalding.
→ The cooling system must be depressurised before being opened.
→ Allow engine to cool down.
6. Open coolant reservoir carefully and slowly in an anti-clockwise direction with gloves and a cloth.
Coolant drain plug 7. Drain cooling system. → 193817 Draining and filling coolant (includes bleeding)
8. Use hot water to rinse out any oil which has adhered inside the coolant reservoir.
9. Close the cooling system and fill the coolant circuit with water only and then bleed the cooling system according to regulations. → 193817 Draining and filling coolant (includes bleeding)
10. Start engine.
11. After the vehicle has been bled and the coolant temperature is > 80 °C, let the stationary vehicle run at medium engine speed for at least 15 minutes.
12. Switch off engine.
13. Open coolant reservoir carefully in an anti-clockwise direction with gloves and a cloth and relieve any residual pressure.
Coolant drain plug 14. Drain cooling system. → 193817 Draining and filling coolant (includes bleeding)
15. Close the cooling system and bleed with the approved antifreeze mixture according to regulations. → 193817 Draining and filling coolant (includes bleeding)
just curious, do I really need to change coolant? if so, how often should I change coolant?
I thought Porsche claimed their coolant are good for lifetime?
There is no coolant change required under normal conditions. ( no intermix oil-coolant by engine or heat exchanger failure )
  • 8 years later...
