hi,
i have the "SportDesign Wheel" 10Jx18 ET65 with tires 285/30 ZR 18 on my 2002 targa, suspension is standard.
any idea what size of spacers can i add without mod the body?
Porsche only recommends their 5 mm spacers (all four wheels) for narrow body cars with 285 width tires. Cars with 265 width rear tires can use 5 mm in front and 17 mm rear.
That's an expensive mod for about 1/5th of an inch 'cause I believe they also recommend longer than the 30mm wheel bolts. :(
o.k. i have just ordered spacers with 7mm each side from Albert Motorsport.
porsche says that the wheel bolts have to be 8 turns inside, than they are long enough. albert says that some original bolts are long enough - i will see!
by the way i will install spacers only on the back.
