I,m about to fit new condensers to my air con. system.When i have it re-gassed do I need some oil introducing at the same time? If so what kind of oil is it,where do I get it and how do you get it into the system? 1999 c4 Cab.
The airco service machine will do the complete job, recycling-vacuum-oil-recharging. All you have to do is report the service men that both condensers are new, he knows the amount and the type of oil for R134a. The system contains 0,900gr. refrigerant.
Chaz2,
+1 on RFM comments. Bring your car to a aircon specialists t orecharge system and inform them you have installed new components. It VERY important that the system is purged of all moisture ( water vapor) before charging with new R134A. At the same time, they can pressure test the system before revharge to ensure there are no obvious leaks before recharge.
Demosan
