I have a 2003 996 Carrera2 Cab Tip with a poorly roof. I'm pretty sure it's the hydraluics as the fluid is low and it makes a whinny and sucking noise when going opening and closing. I am keen to find out the part number for a hydraulic cylinder (arm) and to know if this is an easy job to repair. Porsche quoted me $$$$$!
You help is most welcome.
Thank you.
Thanks for the response, I did find that conversation. They too were asking for the part number and any advise on replacing the hydraulic arm with - no response.
Thanks again.
Thanks again.
How do you know that is the problem?
Item 12 - 996.561.945.02 Cylinder -- US MSRP $658.25 (2 required)
