Loren & Don:
1. I am about to order the Carrera rear spoiler from Gert. His kit does not come with the wiring harness to deactivate the spoiler light. Is this necessary to fool the computer and not get the warning light? Do you have a part number?
2. My center console just arrived. Do you know what size Torx drivers I need for this project?
Eric
Couple of more Q's:
1. I bought the upper center console/A/C surround. It is a one-piece unit. Do you just just pry out the old one and put the new one in its place?
2. I also bought the door handles/storage covers. Can I assume the whole door panel doesn't have to come off to change these? Loren, I know you sent me detailed instructions of door replacement.
Thanks again,
Eric
Hi.
I can answer your door bin question, having just done this.
The door handles come off with a little prising using a butter knife but you need to be careful at the top ends not to snap off the correctors (easily done). The new ones just clip on.
The bin lids can be done in 2 ways:
1. The hard way is to pull out the steel bolt at the handle end of the handlewith some snub nose pliers-I abandoned this as it looked like these bolts were going to suffer from my repeated attempts. If you are successful with this, the bin lids will come off.
2. The easy way is to use a size 6 torx bit on a short handle and unscrew the small screws with the lid open. This was easy except for the screw near the handle end. However, after some manipulating it did come out easily. The new lids can then be screwed right on.
The key to this is to have the torx bit on the smallest handle you can find-mine was about 2 to 3 inches.
I am tod that the central console just snaps off with a butter knife. I was looking for a burr wood one which I haven't yet got so this mod will have to wait.
Im sure Loren will know how to get this off correctly!
Good luck.
1. The spoiler harness part number and detail is in the Tech Tips Section
2. The center console removal is different for MY02 and newer cars. I will need to know your model year. Also, how much are you replacing? just the outside surrounds or the vent and defroster covers too?
RE: Torx drivers.
Porsche uses a wide variety of bolt sizes, I'd just pick up a complete Torx set at Home Depot or your local hardware place. Cheap and ultimately very useful. Another option, and more convenient, is a set of folding torx keys.
I've used virtually every bit in my set although there are one or two sizes that are used much more commonly.
The oil drain plug is an oddball XZN socket, more commonly used by Mercedes. That's the only non-standard fastener I've run across. In general I find my baby surprisingly easy to work on.
Get a set like Jonathan says, as there are many torx fastners on the car. Console needs a 20 and a 30.
I think this is the transmission drain plug Jonathan mentioned. Jeff
Guys,
Thanks for the replies. I picked up a Torx set at lunch.
Loren, my Cab is an '03. I'm just changing the surround piece (upside down U) with the cutouts for lighter, cab top, defroster, etc.
Eric
Guys,
I have the A/C surround off, but I can't figure out how to remove the lighter.
Eric
  • 8 years later...
My '02 Boxster S has a three piece panel here. I was able to gently pry off the two side panels, which then revealed four torx screws that enabled me to remove the horseshoe piece.
Cannot locate the tech Tips section listed above by Loren, is it still searchable because the post was back in 2003? thanks.
Thanks for this post Loren! One thing that I will mention to help others is that there are two tabs (#3 in the diagram), one centered just over each vent louver. This was tough for me to tell until I had it all apart.
  • 7 years later...
Old thread but worth updating.  There are 2 tabs for the air vent removal, they are on either side of the center.  Go through the second louver so you can get a good angle.  The tabs have a small rectangular hole you grab with the corner of a flat end screwdriver and pull down as you are pulling out on the vent.  Do RH side first then do LH side to fully remove the vent.  First time is PITA but afterwards you will see its fairly easy.  Flashlight is your friend.
