I have a liquid dripping from the right front corner ie. from underneath the radiator /condenser.The water level in the cooling system is fine and the liquid is oily so i suppose it cant be anything other than the air con condenser. Would you expect it to be oily - I,ve done the taste test! tastes awful !! Can you direct me to the instructions for changing a condenser - Ive had the front bumper off previously to clear the debris from between the radiators and condensers - is it simply a case of unbolting the old one from the pipes and fitting the new one then getting the system recharged?
