Loren,
do you have DIY instructions for replacing the driver side seat belt receptacle?
seats are memory, power lumbar, no heat.
Thanks Roy
Edited by 911 fly'n
Basically you will need to remove the seat first. For that you will need a Torx E12 socket (external torx). From there is is just unbolting the old receptacle. Remember DO NOT put the key in the ignition - better yet disconnect the battery (so you don't trigger an airbag or airbag light.
If you are trying to do the seat belt buckle update that is a lot more involved (5 page TSB).
