Anyone out there in Renntech land ever rig up a "mute" button for the PCM system....or perhaps re-program another button to accomodate this function.
I don't want to have to search down menus to mute the system while driving, or turn off the entire system just to mute the radio for a minute or two, while talking on a non-bluetooth phone.
Or..... if someone has a wiring diagram that indicates how the non-factory add-on bluetooth systems mute the system, I could probably tap an external switch into that.
Thanks for any help you guys/gals can offer.
Ed 2007 997 C4S :unsure:
Edited by ENK1
Make your switch connect the Mute pin to Ground. See here (the diagram is numbered looking into the connector on the radio):
Edited by khnitz
