I have a questiun about Cayenne S and Cayenne Turbo is there any difference in the electrical installation between this two versions? If anyone knows please help.
Apart from equipment specific differences no. HOWEVER all Cayenne have VIN specific wiring harnesses so its hard to find 2 the same
The question whas because I am changing the engine from Turbo version to S version. If I'll put the S ver. enginge including all electronical equipment and everything from the interior to a Turbo ver. carossery will it work with out changing the wiring?
engine management will be a problem, whats your project, replace a blown engine ?
I have an Cayenne Turbo with blown engine and bought Cayenne S after accident, engine ok so i have all the parts needed to be replaced. To make my question more precised i am interested in the wiring if there are any differences betwen this two version. If ill connect all parts from S to the wiring (cables) that is on the Turbo will it work?
Well you will have to accept the turbo related electronics will be surplus, the dash will be impacted
There will be some need to reprogram the computers so PIWIS will be required
Many thanks for your help and fast replay. I decided to change the electrical instalation and everything is working fine right now.
Reguards,
Michał.
Sorry I do not, I thought it was sealed for life (haha)
Helldo not I o, again do you know maby how to refill oil in the gearbox?
But I do know right now you have to do it on a turned on engine first of all. There is a big screw underneath, screw it out and refill until the fluid start to come out and job done :)
Thanks for your quick respond anyway.
