I would like to remove the spare tire from my 99 C2 coupe for additional storage?
How do you remove the bolt that holds the spare to the frame?
TIA
The easiest way but non-reversible would be to cut it off with a Dremel. I would just leave it; you never know when you’re going to need a spare. GL
the shaft should just unthread, mine did. That way if you ever want to go on a longer road trip... you can just throw it all back in!
For now I just replaced it with a 12v air pump and tire sealent.
