19 wheels and tires
I called my local Porsche dealer today and asked them what size tire is recommended for a 19 inch rim on my 2003 Porsche 996 Twin Turbo.
NOTE: I was told by the Porsche dealer that 19 inch tires, wheels and/or wheelsets are NOT APPROVED for use on 911 Carrera(996), C4, C4S and Turbo.
The Porsche dealer even faxed me a technical information bulletin from PCA North America stating; PAG has not approved the use of 19" wheels on 911(996) vehicles due to safety issues, handling and driveline damage.
Any thoughts ?
JIM
PS. I'd be happy to fax anyone the PCA technical information bulletin. E-mail me your fax number.
The dealer is pretty much required to stand behind Porsche's recommendation of not using 19s. Of course there are a bunch of people running 19s without problems but its a CYA thing for dealers. If you're the one person in a million to have problems with 19s you can't turn around and blame the dealer.
Porsche recommends the 18 for a reason. It seems Porsche does tune suspension utilizing tire size. Based on the attached article I would not go to 19's. BTW in order to keep the same diameter and rolling revs per mile, you will have to go to a lower profile tire. Results will be a harder ride, and if you get a blowout, maybe a damaged rim.
Read this article and it may bring some understanding.
http://www.europeancarweb.com/features/epc...test/index.html
Edited by KevinMac
This assumes you have not upgraded the poor stock suspension. This is a must. I have been on 19's for over a year...no problems, no measurable change in comfort, if anything, with the lower profile tire, the car handles better.
