Does anyone know the difference between fault code P0133 and P1275 (for a 2001 Boxster S)? They both seem to be for the 02 sensor reading ahead of the CAT. I was getting both but the shop seems to have gotten the P0133 to stop throwing, but I'm still getting the P1275. I can't figure out what the difference is.
I have a 2001 Boxster S with a 3.4 L engine, fabspeed exhausts, EVO intake and REVO software if anyone has any ideas.
Thank you.
:welcome:
For your future reference the OBD II fault codes (for your car) can be found here.
P0133 Signal Period for Oxygen Sensor Aging, Bank 1 – Above/Below Limit
Potential causes:
– Oxygen sensor ahead of TWC
– Wiring (oxygen sensors exchanged)
P1275 Signal Delay Time for Oxygen Sensor Aging, Bank 1 – Above/Below Limit
– Leak ahead of TWC or in the area of the oxygen sensor after TWC
Looks like the O2 sensor on bank 1 ahead of the TWC is not responding within limits. If you have more than 60,000 miles chances are it is worn out.
