After a day at Pacific Raceways, I noticed an oil stain under the engine the next day and I feard the worst (RMS)
but it looks like the leak is some sort of bellows over the left cylinder head (see pic).
I assume that the 'thing' on the upper end of the ruber bellows is the AOS?
I had a bit too much oil in the engine (about 3 milimeter on the dip stick), the idea was to avoid
oil starvation in turn 2 (long left sweeper), could that have caused this?
There is no smoke but the idle is rough even after cleaning the TB and the ICV.
Should I replace just the bellows/tube or the whole AOS?
Gunter
99 C2 41K Miles
H&R Street Performance Coilovers
GT3 Sways + Powergrid links
I should replace the complete AOS if i was you, since your car is MY 99. Most part of AOS are already dead at that age.
