:help:
I was wondering if anyone found a fix for this problem (quote below) from Sept 24 2007. I am having the EXACT same problem...only at refueling. Occasional P0446 (carbon cont valve/air vent valve?). I checked all evap lines and all are clear and fuses ok. Could I have a problem with purge valve or shut off valve on the fuel filler neck? I basically put gas in the car, wont start unless you fully depress gas pedal, then runs rough for a few minutes before smoothing back out.
QUOTE (Jeremy Cottrell @ Sep 24 2007, 01:01 PM) *
Well, the problem isn't putting gas in the car, but not being able to start the car after it has been filled up. I checked fuse E6 anyway, because there may be a connection if you suggested it. The fuse is there, and intact
Thanks in advance,
Chris Hewett
2000 Boxster
2.7
160K (65K on new engine)
That sounds like the problem I had. The shop replaced my vent tube, purge valve and charcoal canister. I've filled the car about 6 times since the last repair without a recurrence of the problem.
Good luck.
Good luck.
Thanks heaps, I will try your recommendation and see what happens. I have fixed numerous problems with my Boxster so if I can be of assistance in the future, just let me know. I also have all of the repair CD's... which i have learned is a must if a Boxster owner.
Thanks! :thankyou:
Chris
Thanks! :thankyou:
Chris
Where did you get the repair CDs from? Are they ToolPants' DVDs or other CDs?
Thanks! :thankyou:
Chris
I got the Porsche Dealer Workshop CD manuals and PET from Ebay. Some guy was selling copies I guess from the originals. Would you like a copy?
Chris
Thanks! :thankyou:
Chris
Chris
Please do not sell or distribute copyrighted material here - unless it is your copyright. Thank you.
