Hi all,
Is there a need to change to CDR-220 internal settings when going between Bose or non amplified car? Any output setting since "line outs" are not used.
I sold my old CDR-220 to someone and they claim it sounds tinny but this radio was perfect in my car.
Edited by Marc Gelefsky
Hi all,
CDR-220s have a low power line out, so they're barely going to drive a speaker if they're not amped. All CDR-220 systems had an amp in the trunk.
Hi all,
Not true, my CDR-220 has no amp.
They are likely using the wrong pin outs.
Hi all,
This guy intalled it in a MB500E so who knows. I'm sure he fried somthing.
Hi all,
Here are the correct pin outs for no amp.
Hi all,
My apologies. I was just basing this assumption on what I've seen. I should have done some research.
Your friend should wire up to socket B http://www.beckerautosound.com/pdf_guides/om43-4462.pdf
It says it outputs 18watts x 4, so it's probably going to sound tinny if he's using higher than 20watt speakers or if he has more than 4 speakers wired in as there's not enough power to drive them.
