I'd recommend using the 3.4 throttle body, bit larger diameter and bolts directly up to the 3.2, and the throttle cable just hooks up
one thing we're still working on is the air intake, there isn't enough room for the stock setup so we're having something fabricated to fit better
the car does run and drive with the original 2.5 DME, but we expect a noticeable difference with the later mapping
pic of the engine in, you can see how little room there is for the intake
Edited by Rixter
Including the becoming a contributing member part?. B)
monetary donation made, though I will "contribute" more from expertise/experience over time in the forums
we're done...
much thanks to Todd for his advice, throttle body and programming
the intake issue was resolved by removing a section of the stock intake and replacing it with a section of piping to get under the frame
just a note for those who may do this, to scan the trouble codes you must indicate that the car is a 911 as the throttle body and DME mapping is from the 3.4
otherwise the car runs great, and is very quick
Edited by Rixter
