'01 996 C2. A few thousand miles ago (car has 40k now) the drivers seat started squeaking as my weight shifts while making turns. Quite loudly, actually... not sure where to begin. Is this a known issue? And no, I haven't gained a significant amount of weight recently...
Is it from the seat 'padding' or under the seat (rails)??
If its from the seat padding, specifically the back rest i had an issue. You have to unclip the padding from the from of the back rest. My issue was the 'foam' within the seat was rubbing/squeeking on the meatl surround. I just pushed a piece of folded paper in it and no more issues. I suspect silcon grease would do the job too. You need to locate it first. Good luck.
My passenger seat does it..its where the seatbelt cable/clasp squeaks against the leather. never heard anything so loud from a seatbelt!
