I have a '99 Boxster with 48k on it. Just finished a complete brake job of front and rear pads and cross drilled rotors and now I have a clicking noise from the left rear wheel. Anyone have an idea what it might be? Any help would be appreciated from my fellow Porsche lovers ! Thanks, :cursing: Jake
check the emergency brake cable?
Make sure the pads backing plates are not hitting the disk where is sticks out toward the wheel. Some pads holes make the pade sit lower in the caliper.....
I had the same kinda thing on my car after i did the brakes. I believe it is the brake shield. Does it happen all the time or just when you are turning?
The remedy is to bend the shield out of the way. Stick a screwdriver inbetween the wheel carrier and the shield and pry it over.
I checked the e break and it was fine I will check the shield tomorrow. Thanks guys the help is much appreciated ! Jake
