I would like to hard wire my tom tom but I don't know where to draw the power from. I know most people get it from the fuse box but Im not sure which fuse to attach the positive cable to,an where to plug the negative? Any suggestions would be greatly appreciated thank you in advance.
Please do a search here as alternate power has been discussed many times.
Most folks use the phone prep cable behind the front center console it has both switched and unswitched power and ground.
I just wired another cigarette lighter into the phone connector under the center console. Then plugged my GPS in. I also routed the cable through the dash so it comes out between the dash and the instrument cluster. It makes the install look at lot cleaner.
