Hi, Im having a little problem with my gears... When I shift to second gear it pops out back to neutral.
Its happening more and more, Im wondering what could be the cause.
thanks
Out of curiosity, does it happen only at very slow speeds (under 15 mph) or at any speed?
low speed
low speed
There's certain speeds/rpms where engines and transmissions seem matched up better for shifting. One of my friends claims that if you know where those points are, you don't even need to clutch. I've never seen him do it, and he's quite the talker, but I think there is something to it.
Try avoiding shifting to 2nd until 20mph/3000rpm and see if that doesn't help things out. You might still need new synchros, but it might help you put that rebuild off for a while.
Hey guys,
I am having a similar problem but with mine, it pops out of 1st gear just as I give it some gas. Like Jam996, it is happened a few times and seems to be getting worse.
Same problem???
How much for a new transmission?
All comments are greatly appreciated!
I had a quote for the exchange transmission, 11k can. :cursing:
but I heard it could be fixed for half the price.
thats what I thought by reading some threads, but 11k is from Porsche in Canada.
How can there be such a difference in price? will there be any guarantee if I buy it
from US?
I have been having similiar problem . My car has 24000 miles HOW can that be syncros . I have been told it could be a rusty spring, a plastic clip that holds the cable , broken motor mount,or some kind of guide forks?, all of which would not be much to fix at all!! Heres my problem. When I shift into second gear it goes in perfecly I acclerate press the clutch change to 3rd now if I don't shift and leave it in gear and let off the gas at any speed then it pops out of gear and I can not put it back in . I mean you guys say yeah change the tranny thats stupid if you don't have to.And of course THAT'S going to fix it ... If by any chance I have to replace the tranny. You can bet your balls I'm not spending that kind of money to replace the tranny my car has been babied and I will sell the stupid thing and buy somthing domestic like a vette.... Fukk that.
Edited by 6speed
I have been having similiar problem . My car has 24000 miles HOW can that be syncros . I have been told it could be a rusty spring, a plastic clip that holds the cable , broken motor mount,or some kind of guide forks?, all of which would not be much to fix at all!! Heres my problem. When I shift into second gear it goes in perfecly I acclerate press the clutch change to 3rd now if I don't shift and leave it in gear and let off the gas at any speed then it pops out of gear and I can not put it back in . I mean you guys say yeah change the tranny thats stupid if you don't have to of course thats going to fix it ... if by any chance I have to do that I'm not spending that kind of money to replace the tranny my car has been babied and I will sell the stupid thing and buy somthing domestic like a vette.... Fukk that.
Why don't you take it to a transmission shop and find out?
You can always try a rebuild. http://www.vertexauto.com/ShowItem/208343%...ansmission.aspx
Hey guys before you dump that kind of cash for a brand new gear box do what I did. I was having the sae issue where my car was very hard to get into 2nd gear especially when it was cold and it would pop out as soon as I let the clutch out. I searched all over the internet ooking for solutions and all i found was more and more people with problems. There was no solution out there except to replace the tranny whioch I was not about to do. A good friend of mine suggested changing the tranny fluid so I did. I changed my tranny fluid with Redline MTL and the problem is completely gone. The tranny feels perfect and it hasn't done it a single time since. I hope this helps you guys out! If you don't have a local shop that has it, I reccomend BRITS in Sonoma, CA 707-935-3637, they will ship it to you.
The owner's manual says not to shift to second at less than 15 mph. I stopped doing that, and I stopped having trouble getting into 2nd. See my post above for the link to $2500 rebuilds.
